Anachronism wrote:
The second tube, spontaneously exploded about ten minutes after I installed it.
I've had this with latex tubes, butyl tubes, and bad rims. The tubes were user error. The bad rims had a piece of the hook missing(!) I didn't find that problem immediately.
Anachronism wrote:
The third tube lasted about a month and spontaneously exploded about two minutes after topping it off. Both tubes where completely shredded on the rim side for most of the way around. A careful inspection of the rim and tire and I can find absolutely nothing that could possible cause a tube failure. I now have had a butyl tube in there for about a month with no issues. Front wheel has had a butyl tube all season with no issues.
Sounds like the tube got pinched.
Anachronism wrote:
My normal inflation routine is to inflate the tires to about 120 psi, then bleed them down to 105 with my gauge. 120 is the max recommend on the gp4000s, are they this sensitive to high pressure? What gives, this is getting expensive and a PITA.
Conti tires are "soft". That makes them easier to blow off. They're not the only tires that are "soft".
Anachronism wrote:
Not to mention if it happened in the middle of a ride it could be potentially very dangerous.
I've had a (butyl tube) tire blow of the front wheel at 70 km/h. Yes, it's dangerous and slippery to ride downhill on a rim with no tire.
Heavyweight tubes and tires are safer. Lightweight butyl tubes rupture like crazy. Latex tubes are prone to user error.
Tubeless-ready rims tend to have a very tight tire bead <-> rim hook interface, making them a lot safer for blowouts. There's different rim hook designs.
