I need some advice. I've now had three latex tubes fail in the exact same spot in the past 2 months on my disc wheel. I tossed one of them, but hopefully you can see that it happens right at the seam on the two tubes in the pic below:[/img]
Per the manufacturer's recommendation, I don't use rim tape on my disc. I've checked and rechecked the area around the valve hole on the rim, but it seems to be perfectly smooth to me. Should I start using some rim tape? Did I just get a bad batch of tubes? Should I still trust these tubes if I patch them?
