They may have been around awhile but I've always maintained that the Campy Shamal is still one of the best front wheels out there.
"The researchers also found that some wheels tested , the three spoked wheels and the Hed CX, had a sudden reduction in yawing moment at one point in the angle of the cross wind followed by a sudden increase. This means that the force needed on the handlebars to hold the front wheel straight when riding in a cross wind is changing in an unpredictable way. They concluded that this characteristic would have a serious effect on stability in gusty conditions. They did not find this to be the case with the Campagnolo Shamal. They also found the Shamal to be more stable than any other aerodynamic wheel at low yaw angles. These wind tunnel tests were corroborated by road tests that found that the Shamal was relatively unaffected by crosswinds."
