Anyone have one of these know what the ceiling height requirement is?
Re: Kickr Climb [JFHJR]
I can't imagine the ceiling being a restriction.
http://www.instagram.com/cyclewise
It only lifts the front wheel about a foot (and the saddle less than that). If you can sit up on your saddle currently and have a foot or more of clearance you’ll be fine.
ECMGN Therapy Silicon Valley:
Don’t lose your teeth when the belt snaps and your front end comes crashing down.
Re: Kickr Climb [Ohio_Roadie]
Ohio_Roadie wrote:
Don’t lose your teeth when the belt snaps and your front end comes crashing down.Are there documented cases of this happening?
Don't forget the ceiling fan in your calculations!
"Remember: a bicycle is an elegant and efficient tool designed for seeking out and defeating people who aren't as good as you."
--BikeSnobNYC
--BikeSnobNYC
Re: Kickr Climb [Titanflexr]
Titanflexr wrote:
It only lifts the front wheel about a foot (and the saddle less than that). If you can sit up on your saddle currently and have a foot or more of clearance you’ll be fine.Perfect. Thanks!
I have my bike under a false ceiling I built to hide an HVAC pipe.
i'm 140 lbs and I've snapped 2 kickr climb belts. on my 3rd climb right now but part of me is expecting it to go any time now...
Re: Kickr Climb [johnj121591]
Seriously?
I have one and only use it because I own it, not because I really derive any value from it. Why would you keep using it if this has happened to you?
johnj121591 wrote:
i'm 140 lbs and I've snapped 2 kickr climb belts. on my 3rd climb right now but part of me is expecting it to go any time now...Any new information on the reliability of a Kickr Climb? I finally got into a Wahoo Kickr and Zwift and really like it. The video for the Climb seems awesome but I weigh
a lot more than 140!
Thanks, John
Re: Kickr Climb [johnnybefit]
I’ve had mine for 15months with no issues, and I weigh 180lbs
No real issues with mine, and I've had it (and loved it!) for about 14 months now. Maybe once or twice it semi-quickly dropped a little, but other than that it's been great. If you can afford it you should get it!
Today I do what others won't, so tomorrow I can do what others can't.
Re: Kickr Climb [WatchJoeTri]
Thanks for the feedback on this. I am interested and can afford it.
My road bike has disc brakes - can I use the same skewer as I have on the bike? Or do I need something special?
I can use my rear skewer on my Kickr.
I'd check their website, but if the trainer works with your bike then the kickr climb should work. I believe any kickr after 2017 should work, but double check to be sure
I bought mine in 2017.... it is still in the box (oops)
