Thanks. Looks great! I can't even tell that it is taped. I'll order on tomorrow! By the way, are you running the Bonty tires on those HEDs?
Re: Jet 90 Rear vs. Disk [Tom A.]
By the way, I have the Flamme Rouge 60/90 now. If I buy a 90 front is the extra money worth it in you opinion?
So, the TT is too short to carry fluids...but you need a bento box? What's up with that? ;-)
"100% of the people who confuse correlation and causation end up dying."
Re: Jet 90 Rear vs. Disk [valdlaw]
True, but is there anything tangible to be gained in terms of speed?
Re: Jet 90 Rear vs. Disk [MOP_Mike]
Don't you know that Bentos are fast? :-) Just ask Mark Cote (MITAerobike).
Since it's a TT I ride to from my house, the Bento is to hold my spare tube and CO2 inflator. I figure that's a better (and slightly more aero) way to carry it as opposed to a seat bag, which doesn't fit up too well with an Adamo saddle.
I take a bottle, but just stuff it down the front of the skinsuit and drop it off at the finish as I'm warming up.
I rigged a micro flat bag behind the seat rails on my Adamo with a couple of velcro straps. :-)
Well...the Hed drag charts show that at 10 deg of yaw there's up to an ~50g of drag reduction...which translates to ~0.5s/km.
http://www.hedcycling.com/...dynamics_technology/
Go look at the drag charts and then determine if you think you'll be spending more time in the 0-12.5 degree yaw range where the 90 has a fairly significant advantage, or more time above 12.5 deg of yaw where the 60 is only slightly lower drag.
Thanks Tom, I asked the question poorly. I meant is there a tangible advantage between the Flamme Rouge Jet90 and the standard Jet90.
Hmmm...$200 to save 39g on the front wheel? Ummm...not in my book.
Oh yeah, and I'm not "buying" the ceramic bearings having any measurably less rolling drag ;-)
But...some people like having "the best" (i.e. the "top of the line") no matter the cost...so, who am I to judge? :-)
I forgot to answer this...in those pics there's a Bonty AW19 on the front and an old Michelin ProRace Light on the rear (in anticipation of the upcoming road race). As of this afternoon, there are AW 19s front and back.
BTW, don't forget that my Jet 90s are NOT C2 rims...they're the narrow rims.
Thanks for the advice.
am I just not seeing it, or do you go sans-PT on that?
Re: Jet 90 Rear vs. Disk [lrobb]
Yes...that's "sans-PT", but not "sans-PM"...it's tough to see from the NDS, but take a close look at the crank spider :-)
edit: Here's what the DS looks like:
I ordered the wheelcover today sans fasteners. Is there any trick to taping the thing on? I assume you just go around the outside edge with black electricians tape. I can't tell from your photos that you even have tape on there.
Here's what I do:
1. Starting on the DS, I place the cover over the freehub and center it. I then take 3 to 4 small pieces of electrical tape and place them spaced out around the edge of the cover to hold it in place.
2. I then flip the wheel over and place 3 or 4 pieces of packing tape over the DS spokes and against the backside of the DS cover. This holds the portion of the cover nearest the cassette close to the spokes and makes it less likely that the cassette, chain, or derailleur cage will rub on the cover. I learned that trick from Ken Lehner (Old and Haggard).
3. I then turn the wheel back over and run a strip of electrical tape around the edge of the cover, picking up the initial pieces I placed as I go around. This might be overly "geeky", but I make sure that I go around the cover in the direction opposite the rotation direction. This is so that the cut edge of the tape isn't "presented" to the air flow.
4. Lastly, I turn the wheel over and repeat steps 1 and 3 (skipping #2, of course) on the NDS cover.
This is the tape I use. It's relatively expensive, but it's good stuff. It lays down easy, has the right amount of stretch, and the adhesive is solid. I learned that tip from Greg Steele (gregclimbs).
I hope that helps :-)
Thanks for tip #2 (Tape on the inside of DS cover to hold it against the spokes). It's much appreciated.
I find that it's much easier to mount the cover and keep it centered by using tape instead of screws (I've been following nearly the same method as you). However, until now, I "had" to put screws in to avoid any cassette rub... etc.
Re: Jet 90 Rear vs. Disk [Bell Head]
IME, the fasteners tend to slightly "warp" the covers...the purely taped covers end up much smoother overall. I would tape the edges of the covers anyway for aerodynamic reasons, so I found the fasteners to be a bit of a "belt and suspenders" setup.
After seeing Jens' (ST's Jens) 808 wheel with only tape attaching it (he taped over the fastener holes) and hearing his success with it, I decided to give it a shot.
Part of the reason I use the "high quality" 3M tape is to have less "fears" about how well it would hold up under hot conditions and/or wet. I haven't subjected it to wet yet, but hot doesn't appear to be an issue.
Thanks for the detailed instructions. Sounds like a solid setup.
If you look around, you can find tape with different temperature ratings. The low temperature tape tends to lose adhesion when it's real hot....
Re: Jet 90 Rear vs. Disk [jens]
Da' 3M stuff works well down to at least 3C - who knows what windchill?
I found a 10 pack of electrical tape at home depot, same roll length as the 3M, for $5 or so. It's held on for several races, including one that was cool pouring rain, and two that were warm (low 80s). Didn't notice any loosening.
Tom:
Mounted the disk cover on the Jet90 and put another Jet90 on the front and works great except I had to put a washer on the the non-drive side dropout to fit my transition as the disk bulges out on that side when compared to the non-drive side. Is this right or am I missing something? One side is basically flat while the other is convex. Anyway, seems to work great as tis past weekend I set a pr on the bike with a 24.3 average, which is pretty good for my ability. Thanks for your help.
