On this forum, it seems like every other thread refers to getting a professional fitting on the bike, and there is a lot of stuff out there on what a well fitted rider should LOOK like on the bike, but I don't see a lot of guidance out there on what good fit should FEEL like. To me this is much more important than the LOOK.
<aside> About 10 years ago I did get a professional fittng done, using the Serotta system. It actually worked well for me, and I haven't altered my position much from that original recommendation over the years. But at the same time, there used to be a fair bit of guidance on how to adjust position based on what you felt, and that Serotta session actually just confirmed what I already had, recommendations were a maximum of 1 cm different from my existing settings obtained through feel. <end aside>
Eg, if the back of your knee started hurting first, saddle too high. front, saddle too low. Lower back, need longer stem. shoulders / upper back, need shorter stem.
Using those guidelines, I came up with what was a pretty good position, where everything started to hurt at the same time.
OK, a bit of a ramble, but my point is that the fitter does not ride the bike, the rider does, so only the rider can tell what is right or wrong. Many new triathletes do not know how to interpret the signals given by their own bodies. That is where the most useful guidance will be, and you will probably find that with the right guidance most will be able to come up with a decent position on their own.
And to be honest, I don't see how a fitter is going to be able to tell me whether I should be on a steep or shallow angle, or how high/low my bars should be. Only I can determine that, through trial and error. Where they can help is with reach, cleat position, and saddle height. as often you need an observer to tell you if your knee is travelling a straight up and down path, are your hips rocking, etc. Also, my preferred fit will change depending on the type of event I'm competing in.
Just my little rant. Ride safe.
J.
Swimming Workout of the Day:
Favourite Swim Sets:
J.
