and Frank Day screamed... would the Powercranker explode?
Just wondering.
Catastrophic failure of moving projectiles is generally associated with the sound barrier, however, if one was approaching "c" with powercranks, then einstein would have to rewrite equations as laws of physics would likely break...Max Planck might also have to change the value of Planck's constant since clearly powercrankers go at lower frequency (RPM) than normal photons, thus resulting in Planck's constant to have be revised to end up with the same energy as another photon/conventional cranker....
Hey, Dev - you've had to rehab a few times in the last few years. Did you use PCs during that time?
