I usually go from my trainer or from my run directly into the shower. I let everything soak in hot water while it is on my body ( HR monitor, headband, tri shorts/running shorts, compression top, etc). After its saturated, I'll remove it and wash regularly allowing soap suds to get in the clothes and wring them out. Then I hang them to dry, they are usually dry in a few hours. Much quicker turn around than if I put them in the wash- I may not see them again for a few days. However, I came in from a run yesterday and my fiance said I smelled like a homeless man. Can you relate or am I the only one?
E
E
