Let's keep the AG stuff here and Pro's separately.
Latest relevant content:
a) The bike course: Take a look here: https://forum.slowtwitch.com/...rt_Gearing_P5963706/
It includes a video (of the typical course, but 80~90% is identical with this year).
b) The lake is warming up, nights are getting significantly warmer. Right now 22.9°C (wetsuit yes/no at 24.5°C). Water temperature will be rising the next days. But I still believe that it will be wetsuit legal on Sunday. Even though I would personally prefer it will not be allowed. But I am probably an exception ;-)
c)
hetron wrote:
Do you guys think its mandatory to ride the course? I get in wedneaday and won't have the bike ready until Thursday. Even then, is the traffic bad enough not to ride it? Then again, its Europe. I keep forgetting they're cyclist friendly.
The course is still mainly on very busy roads. Not sure if there might be a guided and secured official loop ride on Thu. or Fri.. Currently, not that I am aware of. Personally, I would not recommend riding it. Will you have a car (which you do not need in/around Frankfurt)? If so, take the car for a recon ride. Or - if going by bike - go very early morning. It is dawning around 5am and should be warm enough around that time.
But is it mandatory? It certainly helps. The course has some twists and corners within small villages that will slow you down if you do not know them. It is also good to know the landmarks in the uphill sections. However, there is not really anything critical. If you want to squeeze out the very ultimate minute, it helps. If you simply want to have a safe and enjoyable race, you will go ok without a recon ride.
hetron wrote:
Also, I'm running a 1x11, 50t x 11-30. That worked fine for cda 70.3. If anything, I could use an extra gear on the descents. What's your setup?
I ride 53/39 with a 26/11 cassette. However, none of the climbs is really step nor long. Looking at the CdA course map and if you can ride low cadence, you should be fine with the uphill sections (I prefer very high cadence, so I need a little gear). But you certainly could make use of a higher gear on some downhill sections. Again, it all depends if you are easy enough to let it roll, relax your legs and "lose" 10 or 20 seconds, or if you are counting seconds...
c)
