johnnyyd wrote:
Im contemplating upgrading my frame this off season and was going to transition to disc brakes. Is there a vast difference between Hydro and Mech?
Also, can I swap out my current Di2 setup if I go with mechanical?
hydraulic is superior to mechanical. as we see, the world is shifting to disc brake. that also means a shift to hydraulic. we will also see a shift to consumer-mechanics. as the mass extinction of the pro bike shop and the move to consumer direct continues, working on your bike means: 1) your great LBS if you're lucky to have one; 2) your mobile repairman; 3) you're doing it yourself.
because some of you are going to be doing it yourself, i've spent the last week boning up on hydraulics, so that i can write and video this stuff to you intelligently. we'll be publishing a lot on this. who makes the best fitting and connectors? the best tools for brake bleeding and brake adjustment? how do you do it? is there a set of best practices?
if you were in my workshop today you'd see a full suite of hydraulic tools, pieces, gizmos all over the place. i'm going to try to help make your future better, but this is for sure your future.
Dan Empfield
aka Slowman
