oscaro wrote:
Ai_1 wrote:
oscaro wrote:
Yes, the most common shoes are Vaporfly, Boston 6 and Adios Boost 3. All have a 10mm drop.
Really not sure where you are getting the idea that high drop is affecting posture, it's a weak core and poor form in general. The hips aren't going to go more forward when you have low drop.
Now what are you referring to when you are talking about clearance? If you are talking about overstriding then that is a problem, but switching to a lower drop shoe is not the only solution.
You said "all pros run in shoes with big drop". I asked if you knew that to be true.
The fact that these 10mm drop shoes are the most common does not answer that question. If you are saying ALL pros wear them, then you're answering my question. But I doubt that is true. I don't actually know the answer, thus the question.
You are also misinterpreting what I've written about any potential link between big heel toe drop and posture problems. I did NOT blame big heel toe drop for most posture problems. I specifically disagreed with the OP who suggested shoe change as a direct solution to posture problems. I do believe there are cases where they can contribute to issues with gait, but to interpret that as you have is not accurate or fair.
Oh come on, of course there will be outliers who run decent times with low drop shoes, but the best in the world all use high drop shoes. Arguing against that is just stupid....
But the fact that there are outliers undermines your entire point, does it not?
You suggested that since
all pros run with big drop shoes, we shouldn't look elsewhere. That argument does not hold water for several reasons. One being that there are outlier and another being that these are pro runners. Why should we all compare ourselves to those at the very top level when most of us are approaching the sport with entirely different abilities and limitations. If I was going to call something stupid it would be the idea that we should always do what the pros do without questioning whether it is necessarily applicable to the diverse spectrum of lower level performers (like me for example).
So, I am not arguing against pros using these shoes. I'm arguing two things. One, that perhaps they don#t all use them. And two, that what they use is largely irrelevant to this discussion.
oscaro wrote:
...There is no way to tell OP what is the best drop for him, but I'm just tired of this running barefoot trend and people preaching about it as if it is a gift from above, when it is clear that the best in the world don't agree....
Who mentioned barefoot? Zero drop is not barefoot. Not wearing shoes is barefoot.
I described in my earlier post how a raised heel can influence gait. If you;re trying to work on your posture, it makes sense to eliminate any unnecessary factors. Heel rise (or toe drop) is an unnecessary factor. It's debatable whether it's advantageous but it's certainly not a necessity.
Two points about the best in the world. They are typically trying to run very fast. As a general rule we don't know whether or not they are working on posture issues. Second, the best runners in the world are not necessarily the most knowledgeable about running (although their coach, physio, etc may or may not be).
oscaro wrote:
Sorry if I misinterpreted your original post, it was this part that I still don't understand "A shoe with big drop MAY allow good posture or may cause problems with heel clearance."
I asked you in the post what you are referring to when you are talking about clearance, I assumed heel clearance was a reference to overstriding, but I may be wrong.
Apologies if that was not clear, I thought it was. I am referring to the clearance between the sole of the foot at the heel and the ground, at the point in time when some part of the shoe makes contact.
I am not making any assumptions about whether the runner is over-striding or whether they are better served heel striking or not. I am simply analysing the manner in which the foot is loaded upon making contact. The loading of the foot effects posture, it's one of a myriad of factors, including over-striding and others which you have mentioned.
Edit: These posts are getting a bit wordy! Congratulations on your stamina if you read the lot! ;)
