natethomas wrote:
Do you have a powermeter? If so, I feel that riding hills is way overrated! If you have the proper gearing, just know what power you should be hitting. Hills for running on the other hand are very necessary for a hillier IM course.Nate is correct. There is no magic to hill climb training. Just get your power up and your weight way down. You can do this on a trainer and a weight scale. This will get you 97% there. Power to weight is the number one thing you have to worry about. You can be a complete climbing stud witih a 4.4Watts per kilo FTP and never touching a hill till race day. The guy with a 3.3W per kilo FTP will be nowhere in sight.
If you want to get specific and you have a smart trainer, what you want to do is some repeats in a low inertia environment, meaning high power and low wheel speed. This will get you in the mode of maintaining more momentum and pedal force throught the pedal stroke vs the quad and glute based pounding downstroke for TTing. This piece gets you to 99% in that if you're the 4.4W per kilo guys and so is the other guy and he rides hills and you don't then you've simulated the low inertia of climbing and done some specificity on the trainer.
Final 1%, assuming all of the above is show up with the correct gearing so that when you're riding at 85% FTP "spiking your effort on a climb" you're still somewhere in the 70-85 RPM range and not bogged down at 55 RPM. If you are overgeared, you won't stay in your power band and instead you'll stay in your RPM band and rather than ride at 55 RPM at 85% FTP, you'll ride at 70 RPM at 130% FTP until you're no longer doing that 30 second seconds later, but doing that a few too many times, and you just added 20-120 minutes to your run/walk split.
