Upfront, I may be the weakest "pulller" in this thread. From a running/cycling background, 64yr, 6' and 145lbs. 100s are at 2:00.
I started doing one arm cable pulls at the local gym to get a feel for a stronger pull than I was experiencing in the water. At first 10lbs was a noticeable pull compared to what I was doing in the water. Have worked up and pretty much plateaued at 20lbs in a 3x5 lifting scheme. On good days, 25lbs 3X5; yet, protecting my left shoulder and don't want to press my luck.
So I'm only doing 20lbs 3X5 while standing and rotating the body some as if I were in the water.
How much weight can you pull with a cable machine?
Is this one of those things where the more you can pull, the faster you are in the water?
Ready to be amazed and dismayed.
Indoor Triathlete - I thought I was right, until I realized I was wrong.
