scott8888 wrote:
My advice is start with a pull buoy. If it make you faster stick to the cheap suits because you need the buoyancy. If your body position is good enough that losing the ability to kick offsets the extra floatation then you need to think more about the more expensive offerings. I enough triathletes literally dragging ass in the pool to know that ultra flexible wetsuits are not always a recipe for free speed.
First, I really can't comment on how my Roka Maverick compares with other high end wetsuits as it's the only high end one I've had. I can, however compare it with the run of the mill Xterra suit I previously used.
I'm definitely faster with a pullbuoy. I'm also definitely faster with my new Roka than the Xterra, despite the thick neoprene of the Xterra. While I'm swimming better than ever this year (at age 66!), in my one race without the suit, using a swimskin, my swim results were mediocre and failed to demonstrate any improvement over previous year's non-wetsuit swims. The two races with the Roka were my best placings in the swim in the 8 years I've been doing triathlon.
I don't doubt that the difference between other high end suits is marginal, but I do question the advice to stick to cheap suits for those helped by a pull buoy. Only one data point, but there it is anyway.
