Last year, I switched my road bike crankset from 50/34 with 172.5mm cranks to 52/36 with 170mm cranks. The change was a very good one for relatively flat time trial type efforts. (TT efforts are my strength, climbing is my primary limiter.) But on mountain climbs, I'm on the order of a couple dozen seconds per mile slower on 8% to 10% grades. Obviously, a switch back to compact gearing should help . . . but there's more at play here. I've read that longer cranks also effectively lower the gearing.
My question is . . . how much difference does a 2.5mm longer crank make when going up steeper climbs? How significant is the effective gearing difference? Significant enough to switch out the entire crankset?
