Hookless Rims - What kind of tires
Thinking of buying some hookless rims but it isn't clear whether you use clincher tires or tubeless with these. Anyone know? Thanks.
Re: Hookless Rims - What kind of tires [justtrime] [ In reply to ]
What rim and width? What pressure are you hoping to run? Lower pressures on wider rims you can get away with a little more, higher pressures and you may want to stay with a true tubeless ready tire.
Need some more details.
Use both/either. There is still a hook with hookless rims.
Re: Hookless Rims - What kind of tires [Nazgul350r] [ In reply to ]
Umm, no there is not.
There is usually a beadlock lip on the base of the rim but no hook and usually lower rim walls.
Re: Hookless Rims - What kind of tires [lyrrad] [ In reply to ]
I should have worded it better. They do not have hooks in the traditionally way, there is a small channel that the tire "hooks" into now. This is from Alto.
“It essentially came down to the profile of the tire bed and making that channel so that the air pressure wouldn’t be able to lift the tire over the sidewall,” says CEO Bobby Sweeting. “So it’s the height of the sidewall and the depth of that channel that the bead locks into so the pressure is pushing the tire outward against the sidewall and not upward over the sidewall.”
No clincher tyre will engage with that lip, and the clincher bead is designed to engage with a standard rim hook which is at a larger diameter, so your advise to use any type of tyre is simply dangerous.
Ok, so do I have to use a tubeless tire?
That won't work either. THis seems like a design that was invented over a few (too many) beers.
My only experience with hookless is Enve’s SES 4.5 AR and they recommend only tubeless tires whether running them with tubes or tubeless. See tire recommendations here for examples: https://enve.com/products/ses-4-5-ar/
Definitely tubeless tires only.
The rim manufacturer should specify minimum tire width and maximum pressure, as Enve do with their 4.5 AR.
"https://altocycling.com/...ducts/ccx28-clincher"
Alto makes hookless disc rims and states to use standard or tubeless clinches.
Re: Hookless Rims - What kind of tires [Benv] [ In reply to ]
Actually it works fine. Roval and ENVE were some of the first to build hookless mtb rims and more recently it has move to road and gravel designs like Alto’s & Mavic’s newest. It’s generally a disc brake and tubeless design such as the 4.5AR noted, which was one introduced two years ago.
