Hi,
A friend has a 2016 Argon E-118 (rim brake) and was looking for a way to be able to tilt his elbow rests and extensions and be able to use D2Z ergo extensions. Also since Argon clamps are pushed forward the D2Z poles wont work in the stock setup. He purchased a Tririg Alpha X but realized his Argon has a proprietary stem/fork so that wont work.
Is there an aftermarket clamp/tilt that works with that weird Argon E-118 base bar?
Is there an aftermarket base bar that allows you to tilt the clamps/rests with plenty of adjust-ability?
Attached is a picture of his bike front..
Thanks for the help.
jcenteno1287: Mar 8, 21 7:52
