joshatsilca wrote:
Anne is right that it's all about ventilation. Bedouins can/do wear black because it allows less light penetration to the skin for a given weight and breathability of fabric, and for lightweight fabrics the amount of additional heat it can hold compared to white is negligible.
For road helmets this is the same story.. it's all about the ventilation and while you might be able to find a small temperature difference on the outer surface of the helmet, you can't see anything inside the helmet as that temperature is purely driven by airflow.
Low ventilation aero helmets, however, are not the same story. In my previous life I was part of a team test where we measured 2-5 degrees C difference between aero helmets with white/shiny finishes and matte black ones. While this isn't the end of the world, it can most certainly be a factor over time.
Josh, thanks for the insight. Can you provide some additional details on the test protocol? Examples: what kind of helmets, how/where were measurements taken, environmental factors, etc.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
