RowToTri wrote:
Why do you not believe the higher yaw data (what defines high)?I wouldn't say I don't believe the high yaw data, I think it's accurate for what it measures, but it's less applicable for simulating on the road performance. For me, the issue is that for conditions near the separation yaw angle, the steady state assumption used in the wind tunnel doesn't do as good a job representing conditions in the field as smaller angles. Away from the separation point, as angle or speed changes, you might move a little up or down the drag curve but you always follow the curve. Near the separation point, however, you run into issues of hysteresis. That is, let's say the average wind speed and angle are such that you're just below separation and a gust of wind comes along. The higher actual wind speed will momentarily increase the yaw angle and the flow separates (increasing drag), but then when the gust passes and the wind speed drops back to the average, the flow will not reattach in the same way it separated when the speed increased. In other words, you're following a different curve on the way down than you did on the way up and the average drag will not be the average over the steady-state curve.
It's possible to measure this hysteresis in the wind tunnel and it's happening more and more, but since it depends on the rate of change of the wind, it's difficult to get data that can be generalized.
