domingjm wrote:
dgutstadt wrote:
domingjm wrote:
dgutstadt wrote:
for me (n=1) placing the oh1 on the goggle strap works great. i had the hr-swim for a while, very uncomfortable (and the hr-tri will not stay in place in a pool).
as mentioned, only garmin chest straps will download hr at the end of the swim to the watch. however, with the oh1 you can record the session and then download the file from polar flow site and import as additional file into the activity in trainingpeaks. you can select how the TSS is calculated - based on swim critical pace (the garmin file), hr (polar file) or let TP combine them. in any case you can see all the data together after importing. its a bit more effort and is totally manual but it works.
And is that only if you do a single set, or can this be broken into, say, 4 sets and distributed accordingly?
I don't stop and start the oh1 on every set. It just records a single session, oblivious to what I am doing. The garmin watch keeps the sets.
When you overlay the files in TP you will see your sets from Garmin and the HR for the whole session, including rests
So if you were going to do, say, 10 x 100, 5 x 200 and 10 x 50, you would just let the OH1 continue to run? But you would save the Garmin data as three separate data sets, as opposed to one, right? Thanks. I'd love for this to be compatible with what I'm trying to do.
No, its simpler than that. Record your sets in one session on the Garmin (hit lap button for resting and lap again to go) and the HR in one session on the OH1. Sync the swim session from Garmin connect to TP. Download the HR file from Polar flow and upload it into TP in the same session from Garmin.
Here's an example (WU, 200's, 100's, 50's):
http://tpks.ws/...CZEPXHPO4RKLDQB7PQKQ
