@BW_Tri wrote:
vanchize wrote:
quit listening to these salesmen who give you a limit on how many phone calls you can give them every month.
Let me guess, you expect a coach to provided unlimited time to all of your needs for a flat rate? Because surely time does not =$$$ where you come from!?!?!
Surprisingly, I can hardly get any of the athletes to use the allocated time I provide them on a call. Almost everyone exclusively prefers text/email.......
Self coaching works for some (same can be said about canned plans), but for many they will end up burned out, injured, or plateauing sooner than with the oversight of a coach. Coaching was the best investment I made in the sport, and would highly recommend that if someone can afford it, then it's very much worth the ROI.
But what do I know...........
It’s like you said, most people aren’t going to use the allotted time every week anyway, you should have a rough idea of how much over the phone contact there will be each week, on average. So build that into the rate..
Other ideas, which you may or may not be doing, and may or may not work for your coaching style, but they’re at least some ideas. You can do things like set up group calls, talk about things that are common to the group (for those comfortable with that), to reduce the number of one on one calls where everyone is asking about the same things. Or a prerecorded video that should be an explanation of the day /week, watch this and then set up a call if things aren’t clear.
There are all kinds of ways to efficiently and cost effectively increase the amount of personal interaction.
Swimming Workout of the Day: Favourite Swim Sets: 2020 National Masters Champion - M50-54 - 50m Butterfly
