Garmin 920XT - No bike speed...
Having an odd issue with my 920XT. I just use the watch, no speed/cadence sensor, and has always worked in the past.
Lately when biking outside, it connects to satellites, and it tracks my distance and time, but it shows the speed as zero. Same for elevation.
Tried google, can't find anything. Anyone else experience this?? I find it very odd that it tracks my distance but not speed....
Re: Garmin 920XT - No bike speed... [SBRcanuck] [ In reply to ]
Do you have a power meter that is supposed to transmit speed....like a PT hub?
Re: Garmin 920XT - No bike speed... [Tom_hampton] [ In reply to ]
Nope, no power meter.
Does Garmin Connect show a speed graph and data?
If it does, you have somehow changed your display for speed to something that you don't have or something that isn't working.
"...the street finds its own uses for things"
Re: Garmin 920XT - No bike speed... [AutomaticJack] [ In reply to ]
Garmin connect shows my average speed in the summary, but if I drag my mouse along the ride, it shows 0 speed the whole time.
That means the watch is no longer doing the calculation. I would try a hard reset. If that fails it's probably time for an upgrade.
Did you try a short outdoor run? Do you get pace there? Trying to debug before you go nuclear and do a hard reset, which whacks all your settings, data on the watch, etc. Even if you choose to do the hard reset, I'd do a soft reset 1st as that might cure your problem w/o data/settings loss. Use the hard reset last.
Re: Garmin 920XT - No bike speed... [giorgitd] [ In reply to ]
It gives me my outdoor run pace (again, no foot pod or anything used, just the watch) no problem, as well as open water swim pace.
But just when biking, distance and time are clicking along fine, but speed shows zero.
Maybe the unit is paired or is trying to pair to a speed sensor; I would check that and, in case, unpair it. Another thing to try is to create a new bike profile, and see whether this revives speed parameter
