Hi,
I've been trying a new position and material choices, trying to validate it with virtual elevation, and was wondering if I could gather some feedback.
First, the position in race setup (except for the empty bottle cages which I would remove):
Second, for CdA tests, I did 9 out and backs (3.5k, about 2mi total), on a calm evening along Zurich airport (440 m altitude, 16 C, 964 hPa, 5 km/h wind according to the airport weather station).
Goal was to test
a) rear wheel, RON Aeron X disc wheel vs Zipp 858.
b) helmet, MET Drone wide body vs Giro Air Attack.
Otherwise same setup as in the video, except for clothing as it was a bit coldish, see https://www.instagram.com/p/CFxRzeshHyr/, taken during cooldown.
Results in terms of time and wattage from Powertap P1 two-sided pedals are below:
(Round #8 was faster, with my twin brother drafting at 10m, to see how much it affects his CdA. #9 was with a slightly different hand position.)
Fit file is attached, which I looked at using the Aerolab Chung plugin in Golden Cheetah.
It is clear that the MET is faster than the Giro for my position, but I find it hard to draw a conclusion on the wheel (I would say slightly better for the disc, but not sure if I'm not trying to justify buying it...)
What do you think?
Jean-Claude
https://besse.info/
https://www.strava.com/athletes/2012033
Goal was to test
What do you think?
Jean-Claude
https://besse.info/
