I looking to get a Rotor crank to eventually use with a power2max powermeter. I currently have a BSA bottom bracket frame, meaning only the original Rotor 3d would fit. However, rotor developed the BSA30 bottom bracket set, so use BB30 cranks in a BSA frame. This allows me to run the 3d+ crank as well.
http://www.rotorbikeusa.com/products/bsa_bottom_bracket.html
Does anyone has experience using this bottom bracket set? And does it work well? I am wondering, the BB30 3D+ crank is theoretically stiffer than the 3D crank because of the larger crank diameter (or lighter for the same stiffness). Would this advantage be offset by using these BSA30 bottom bracket when using it in a BSA frame? I can imagine the thinner bearings might be less stiff/wear faster?
