Nolegs wrote:
teamheadwind wrote:
Ok, so had my yearly physical in July and labs came back with an elevated PSA of 5.46, Dr thought it was an anomaly as I did CDA70.3 three days prior, ordered another test 30 days after and said stay off the bike for a week prior to bloodwork, which I did. Came back 5.79 and he's referred me to a Urologist. Getting a bit freaked out as all my other labs have been great over the years and I have never had any medical issues other than wear and tear, so now entering unknown territory.
Any thoughts or what to expect next?
I'm 56 / 162lbs / 6'1"
Thanks!
Last year I was in a very similar situation that you are in now. My entire life I have never had any abnormality in my blood work until I was 62 years old. Sure enough it was a PSA score of 5.6. A fairly large jump from the previous year. Absolutely convinced I had prostate cancer off to the Urologist I go. He examines me and then schedules a specific PSA blood test that breaks the PSA into "free" and "bound" fractions to further assess my levels. New PSA blood work still indicated a problem so a biopsy is scheduled. While the procedure did not sound too appealing it really wasn't that bad. All of my concerns were focused on what the biopsy results would show. After holding my breath for a week it came back negative. My next examine is scheduled six months down the road.
This whole procedure started me thinking as to what else would have caused a high PSA score if I did not have any cancer. Could it have been high volumes of riding my tri bike in an aggressive position causing micro trauma to my prostate gland and elevating my PSA (
https://prostate.net/...t-increase-your-psa/)?
So I decided to just ride my road bike (which also happens to have a saddle with a very large center cutout) for 6 months prior to my new blood work. I also added pomegranate juice to my daily diet. This juice is supposedly prostate friendly so why not. I go back for my 6 month PSA blood work and now my score is 1.8. Urologist looks at me, smiles and says, " What ever you're doing keep doing it and I'll see you in a year".
My advice to you is go for your examination knowing a high PSA score is not a guarantee you have cancer. If a biopsy is ordered don't sweat it. Nobody is a bigger baby than me and if I tell you the procedure is really not that bad believe me. Good luck and keep us informed as to how everything goes.
So not sure about the juice thing, but a high PSA itself does not -cause- prostate cancer. So not sure if there was any reason to change your riding habits.
My father also had PC, with a gleason score of 9 & 10 in biopsy samples. Given the aggressiveness, he was incredibly lucky that it was confined to the gland and close seminal vesicles, and they actually managed to cure him with ADT, IMRT and low dose taxotere (cure as in, its been about 8 years now, still PSA of zero). It was a hell of a ride for him though, due to the size of the tumor and the associated side effects of having a bleeding lump that big down there...
For me, at age 45, I'm not sure what I should do. As others have said above, family members say I should be tested. My Primary care doc says no. SHe did a few baseline tests like 6 years ago, but since then, she has said that if no symptoms and staying healthy, the recommendation (at least here in Canada) is to not test. I can honestly see both sides of the argument, and agree that there is no easy answer...
To the OP, if mine were elevated that high, I would want further testing to confirm what was (or wasn't) going on, hopefully its nothing.
Cheers
