I am probably about to buy a little USB rechargeable pump for travel races. The two I have seen are the Fumpa and Cycplus. There really are not many threads here, and the ones I found are a couple years old. Does anyone have either of these, or something else they love. The Cycplus is $50, and the Fumpa is $200. I am not opposed to the Fumpa if it is really awesome and worth 4x more than the Cycplus. But, it seems like that Cycplus perfectly checks all the boxes for a transition pump.
These are my requirements:
The two I am interested in:
https://www.amazon.com/...tables/dp/B0798RZMHJ
https://www.fumpapumps.com/shop/fumpa/
- Must work with disc wheels. It looks like the Fumpa does, but I am unsure about the Cycplus.
- Must work with removable core valve extenders. I saw one comment that the Cycplus does not work with "tube type" extenders. Not sure what that means, but I think I am OK with removable core extenders.
- Must have a reasonably precise pressure gauge. I am not looking for perfection, and precision is more important than accuracy. I have a very accurate external gauge I can use to validate the readings, if I need to.
- Must be able to fully inflate the night before check-in.
- Only needs to top-off the morning of the race
