IT wrote:
The recommended products for disinfecting the coronavirus use chlorine.
Does a good swim workout give us a layer protection that lasts the day? How much chlorine do we take into the body and how long does it last?
Seriously???????
By that logic people should be drinking surface cleaners on a regular basis to ward off infections.
Important Note: DO NOT drink surface cleaners!
You're talking like chlorine is some magical substance that might imbue you with immunity.
Disinfection and sterilisation methods in general are about direct contact for a sufficient period between the agent and the pathogen.
If a piece of material or a creature is contaminated externally with bacteria, viruses or fungi and you wash it sufficiently well with effective agents you can expect to kill or inactivate the pathogens present and make them safe. If the pathogen is within the material (inanimate or animate) then, washing it externally doesn't do much except perhaps reduce the contamination it will spread to it's surroundings. How would you to bring the agent into contact with every cell of the pathogen?
There are a few ways to kill most pathogens including heat, radiation and chemical agents (bleaches, alcohols, etc).
However these are not generally useful for treating patients after they've become infected, because a sufficient level to kill the pathogen typically also kills humans.
A sauna won't eradicate your flu any more than a wash in chlorinated water, because it's just a surface treatment (and I doubt your skin ever gets hot enough to even achieve any surface disinfection or it would also damage skin cells and burn you). You'd have to literally cook someone (well done) to kill most pathogens in their body - not very useful. Similarly radiation like UV might provide some effect at the surface for certain pathogens but you would need a full body exposure to sufficient dose of radiation to kill the pathogen. I'm going to hazard a guess that you'd reach a lethal dose long before you'd kill off all the other life forms inside your body.
TLDR - No
