did I understand it wrong or is there an error in the JC article on water bottle aerodynamics? He says at 30 miles an hour there is a resitive force of 7.5 lbs, which means "that every exposed square inch of surface of bike and rider has a force of 7.5 lbs to overcome at this speed"
I believe 7.5 lbs is the total aerodynamic force on the rider and not the force per square inch. 7.5 lbs at 44 ft/sec (30mph) is 330 ft-lb/sec or almost 450 watts, a reasonable power to overcome 30 mph headwinds. The typical rider probably has an effective frontal area of well over 100 square inches which would require a power output of 45KW to attain 30 mph if it were 7.5 lbs/sq-in force.
It is a small point of correctness as it doesn't effect the overall data collection or assumptions that can be drawn from the study but has been bothering me all day.
Frank,
An original Ironman and the Inventor of PowerCranks
Frank,
