I have just bought all the Di2 components and plan to put it on my IA16 on a coming weekend. I have been unboxing the equipment and have a question. I just wanted to check the battery charger and junction A to make sure they are working and connected them and nothing happens, no lights on battery charger and nothing on junction A. I attached the shifters to the open ports in junction A and still nothing. Am I doing something wrong? Could one of these components be faulty? I was not expecting to have a problem this early, ha. Any advice is much appreciated.
Re: Di2 rookie question [Kmck27]
Connect your battery. I believe it is the brains of the system.
Re: Di2 rookie question [exxxviii]
Got it. I thought it may all have to be connected first. Thanks!
For charging, I'm pretty sure you need to have the battery connected too. For using the etube software I don't think you need it though, and that is really the best way to figure out if the component is faulty. Plus Then you can update the firmware if needed/wanted.
Strava
Strava
