Hi,
I have Di2 on my TT-bike with the newer 1-button shifters on the extensions(SW-R9160) as well as the brakes (ST-R9160).
This pretty much mandates the use of full synchro-shifting if you want to shift the full range of gears from the basebar as-well as the extensions.
For this to work, you also need to assign all 4 buttons to only shift the rear derailleur.
That's my current setup and it is OK, even though i still can't get as smooth a shift down into the smaller ring under load (including corresponding upshift of the RD) as with mechanical shifting. It is just slow and noisy and i have to soft-pedal for at least 2 seconds.
So I wanted to give manual mode another try.
Yes - I can reconfigure with e-tube so that the base-bar shifts the FD, but why can't it be configured so that the basebar shifters shift the rear mech in full synchro and the front-mech in manual or semi-synchro mode? That way, I'd just have to switch the shifting mode (which you can do while riding) and not reconfigure the base-bar-buttons with e-tube.
if you can read this
YOU'RE DRAFTING!
YOU'RE DRAFTING!
