Di2 Shift setup help
I'm building up a gravel bike and have managed to get my hands on a demo Di2 setup.
R785 Shifters
XTR RD
SC-M9050 Information display
Much to my disappointment I see that the M9050 isn't Bluetooth compatible as the new 9051 is. How do I set up / change the shifting options on my setup? Is there any option outside of taking it into a bike shop?
Do I just connect the battery charger to the Information Display and my laptop and run the E-Tube software?
I want to change shifting so that right side shifters go up and left side shifters go down.
I'm running 1x.
Re: Di2 Shift setup help [TriNewbieZA] [ In reply to ]
HI, Yes through the BCR-2 charger/Laptop into the junction A (display unit), do it all in place so you can update all hardware with latest firmware, then customize your settings. Our most common setup with !x gravel bikes is to replicate the right shifter with the left, so if you have an off and break the shifter, you still have functionality the opposite side.
'to give anything less than the best is to sacrifice the gift'...Pre
Re: Di2 Shift setup help [undies] [ In reply to ]
Thanks.
Replicating the shifters is a great idea....I hadn't thought of that!
