M~ wrote:
Lately I have been doing a lot of introspection and I have come to the conclusion that
A. I don't like to fail and more often than not, that causes me not to try
B. When I have a plan and it doesn't go EXACTLY as it should, I get discouraged very quickly and abandon the plan/goal.
I want to get over that. What sorts of things do you guys do to get over disappointments and setbacks. For instance, if I had a workout scheduled for tonight and I don't do it, I would get really discouraged and would likely cause me to miss multiple days of workouts and then that would just spiral causing even more missed days and feelings of discouragement.
So, any tips? Sometimes I wish I was more type A personality instead of a type L or M. :)
Mark
None of that strikes me as the least bit unusual.
A/ is the trickier one IMO. I have a bit of the same. It's not fear of failure, so much as lack of motivation if objectively the chances of failure are extremely high..... I should point out that I don't subscribe to belief or willpower being physical properties! ;)
Are you setting the target too high or just too anxious of failing? Maybe consider that not trying is the real failure. Every day that you keep trying is a success in itself, the final goal is just an output of that process. i.e. It's not all or nothing. The training is more important than the event, unless you're a pro, or really, really insecure.
B/ used to cause me problems when I started training. I was a big perfectionist right into my early 30s which typically meant I'd either get very annoyed by or lose enthusiasm for anything once it went became irrecoverably flawed. If my adherence to my training plan was imperfect, that took half the good out of it, and there's always some hiccups, so there was always frustration. I have largely gotten over that, both in training and other parts of life. Using the training example, I think the secret is to decide, when you are assembling the plan in the first place, that it's not a prescription. Instead, it's a list of the activities you would undertake IF you were to train on all of those days. But you are not committing to doing all of that training. You are committing to following it's intent as far as possible. Since beating yourself up about missing one or more sessions is counterproductive to it's continuation, success is defined as getting back on track. The plan is not your boss, it's just something to help you decide what to do today. Missing a session is not a failure, since the plan is dynamic. Every so often you check how the plan corresponds with reality. If it's still somewhat realistic, leave it alone. If not, tweak it to suit. It should remain optimistic so you're not under the illusion it has now become a prescription again.....
I should mention I don't subscribe to the personality type stuff. Nothing's that neat and tidy, I consider it more misleading than useful. Nevertheless, bear in mind that you, with a different set of drives, wouldn't be you. It'd be some other guy. Not much point wishing you had a different mind, it's meaningless!
