I know it use for rear derailleur but is it able to set up(in shimano di2 software) for pushing two bottom at the same time for changing front chain ring?
Re: DI2 Dura Ace Single button shiftier question [UnUnU]
No
Re: DI2 Dura Ace Single button shiftier question [dfroelich]
With a little bit of electronics in between, yes.
Re: DI2 Dura Ace Single button shiftier question [lyrrad]
Wouldn't just be easier to use two button shifters instead, and when needed they can be programmed as a single button shifter..
I know this is obvious for most, but for someone not knowing anything about di2 and stumbling upon this post, what it happens is, they don't just control the rear derailleur, but they will also shift the front derailleur when you drop enough gears, and by long press, you can shift 3 gears iirc
Re: DI2 Dura Ace Single button shiftier question [lemos]
lemos wrote:
I know this is obvious for most, but for someone not knowing anything about di2 and stumbling upon this post, what it happens is, they don't just control the rear derailleur, but they will also shift the front derailleur when you drop enough gears, and by long press, you can shift 3 gears iirclyrrad wrote:
Re: DI2 Dura Ace Single button shiftier question [exxxviii]
exxxviii wrote:
lemos wrote:
I know this is obvious for most, but for someone not knowing anything about di2 and stumbling upon this post, what it happens is, they don't just control the rear derailleur, but they will also shift the front derailleur when you drop enough gears, and by long press, you can shift 3 gears iircThe single-button shifters are meant for full Synchro mode. The buttons control the RD only. So, in synchro, the system (not the shift buttons) automatically shifts the FD for you.
lyrrad wrote:
With a little bit of electronics in between, yes.You would have better luck hacking the CAN bus firmware in the battery than designing a CAN bus interface that could emulate eTap FD shifting.
Actually, no hacking required.
One dual button shifter gutted and the chip used in conjunction with the current dual single button setup.
Shifting for up down rear is an OR function and front shifting is an AND function.
Very simple discrete components.
Shimano stuff has no idea it is not a legit four button setup.
Already done it and the bits shrink wrapped and pushed inside of aerobar.
lyrrad wrote:
One dual button shifter gutted and the chip used in conjunction with the current dual single button setup. Shifting for up down rear is an OR function and front shifting is an AND function.
exxxviii wrote:
yes, you put it clearer than I did :)
