Crazy swim pics from Malta
And no, the swims were not cancelled, well, apparently the 11th out of 13 was. Just found out. Plus slow teams were not allowed to tackle 12 and 13
https://www.slowtwitch.com/...mrun_Malta_7502.html
Re: Crazy swim pics from Malta [Herbert] [ In reply to ]
Fabulous photos.
All triathlons should have swims like that 😁
It's because they are allowed to wear shoes during the swim it really helps a lot... /pink
Why are they allowed to use paddles and floaties?
Re: Crazy swim pics from Malta [M~] [ In reply to ]
For one they are attached to each other, for two the conditions are rough and for three so they don't drown, plus they are in shoes. I really don't know the real answer.. just my guesses, I am also curious.
source https://otilloswimrun.com/rules/
4 Equipment4.1 GENERAL ABOUT EQUIPMENT
4.1.1 All teams need to bring all their equipment from start to finish, if a team fail to bring all their equipment to the finish line they will be disqualified.
4.2 MANDATORY EQUIPMENT PER TEAM
4.2.1 Per team in World Series/Sprint/Experience
– 1 First aid pressure bandage, packed waterproof
– 1 Neoprene wetsuit per person suitable for the current water temperatures. If the water temperature is above 19 degrees Celsius you can choose to not race in a neoprene wetsuit. If you do so you must use a pull buoy.
– 1 Compass/Watch Compass
– 2 Whistles, 1 per person
– 2 Foldable cups/soft flasks or similar (not your swim cap) to drink from at the energy stations
4.2.2 Per person Solo Sprint/ Solo Experience
– 1 Neoprene wetsuit suitable for the current water temperatures. If the water temperature is above 19 degrees Celsius you can choose to not race in a neoprene wetsuit. If you do so you must use a pull buoy.
– 1 Whistle
– 1 Foldable cup/soft flask or similar (not your swim cap) to drink from at the energy stations
4.3 MANDATORY EQUIPMENT THAT THE ORGANISATION WILL SUPPLY
– Race bibs that must be worn visible all the time during the race
– Map
– Timing chip (lost or not returned timing chip will be charged 100 Euros or equivalent)
– Swimcaps that must be worn visible during all the swims
4.4 RECOMMENDED EQUIPMENT
4.4.1 Tether
4.4.2 Water bladder
4.5 EQUIPMENT CHECK BEFORE AND AFTER THE RACEBEFORE START AND AT THE FINISH LINE WE WILL RANDOMLY SELECT TEAMS FOR A CHECK OF THE MANDATORY EQUIPMENT. IF THE TEAMS ARE MISSING ANY OF THE EQUIPMENT REQUIRED, THEY WILL GET A 15 MINUTE TIME PENALTY PER ITEM.4.6 EQUIPMENT THAT IS NOT ALLOWED
4.6.1 The maximum size pull buoy that you can have in any ÖTILLÖ race is 32 cm x 30 cm x 15 cm. If you want to have more than one pull buoy the total size cannot exceed 32 cm x 30 cm x 15 cm.
4.6.2 No wetsuits can be modified with paint or color that washes off in the water. This will result in immediate disqualification.
4.6.3 Swim fins are NOT allowed if the fin is longer than 15 cm. Measurement is from the toe to the end of the fin.
Because you swim with shoes - paddles and buoys are allowed but not required. Also with so much running wrapped around the swims folks try to save their legs for running. :-)
Re: Crazy swim pics from Malta [MTL] [ In reply to ]
Apparently swim 11 was cancelled. I was wrong
Is the tether mandatory or optional? The rules make it sound like an option, at least to me... at first glance. The concept of swimrun is really appealing to me but the idea of being leashed to my teammate is not.
Is it a requirement to wear your shoes or do they just do it because it is easier and faster?
Taking your shoes off and storing them while swimming and then putting them back in is a nightmare time wise - plus you want to run in and out of the water and not walk gingerly to avoid rocks, shells, roots etc
I spent a semester living and studying in Malta during my college years. It’s been 14 years since I was there, very cool to see some great photos from around the island
Matt
Re: Crazy swim pics from Malta [Chemist] [ In reply to ]
That looks like the most fun ever. The Kauai crew I hung around with way back in the day would have excelled at that since swimming in ridiculous conditions and doing the rock hop to retrieve a surfboard was a required skill.
"They know f_ck-all over at Slowtwitch"
- Lionel Sanders
Re: Crazy swim pics from Malta [Fuller] [ In reply to ]
There are great such events in the USA too. Ödyssey Casco Bay with amazing ocean swimming, SwimRun Lake James in early April with lots of lake swimming and island hopping. Ödyssey Orcas Island in September is more run heavy but stunningly beautiful. Our SwimRun NC race the last Sunday in October is also run heavy but very vertical with very cool waterfalls, plus several others including ÖtillÖ Catalina in February and Ödyssey Les Cheneaux Islands in Michigan that is very swim heavy.
https://www.slowtwitch.com/...n_Rankings_7483.html
Malta video is up. Those swims look awesome. I hope we get some of that in Catalina in a few months.
https://www.youtube.com/watch?v=rx4jimocFl0
Facebook and Strava
