SBRinSD wrote:
I use a very wide roll - I believe it is from Costco. I wrap the front brake first. Then the head tube / stem. I also wrap the brake levers, as found I was corroding the levers too. I try to keep all the seams so they aren’t catching and holding sweat / water.
I lay a towel on top, which does the bulk of the work and limits the size of the puddle that builds up underneath the trainer.
I found the towel around/ontop of the front brake is key. The saran wrap wasn't helpful for me because it doesn't soak up small beads of sweat - it was more of a pain to deal with than not. A small towel around the top though soaks up everything and keeps things nice.
