Re: Controlling the Kickr via external power meter now possible [Horchata] [ In reply to ]
I haven't had the chance to upgrade my kickr yet as I don't have an Iphone. I have vectors on my bike that control the kickr through TR and now just use the resistance mode instead of ERG mode since you get a big spike in power at the start of an interval when in ERG mode which can be quite an issue especially when you are doing VO2max and anaerobic intervals, the intervals are usually hard enough with out a spike in power at the start, the last thing I need is to push through an extra 100w for 5-10sec at the start of an anaerobic interval.
In resistance mode I can create much smoother power through the intervals in a session than what ERG mode can, so really I could just use a fluid trainer with TR and my vectors and get exactly the same result, defeats the purpose of having this expensive kickr really
Re: Controlling the Kickr via external power meter now possible [Brad81] [ In reply to ]
Exactly what I could have written. Yeouch!! That first few seconds of a high L4 to L5 interval combined with a spike is absolutely brutal - IMO. I've tweaked my knees coming from low rest resistance to that spike. I tell you the other thing I have experienced in both TR and PP at random times is the resistance not easing up once the interval is done. That too is painful when suffering badly and barely making to the end of the higher intensity interval and then resistance is held another 30 seconds or so past the interval. That too is brutal.
I may need to add some intensity ramp segments of a few seconds in front of the training intervals so that the Kickr has some time to adjust rather than having an abrupt rest to interval jump.
Re: Controlling the Kickr via external power meter now possible [Felt_Rider] [ In reply to ]
I've actually seen the "erg doesn't adjust" bug when coding in Tour de Giro. We'll send the thing a "adjust erg setting to ___W" ANT+ packet and it will acknowledge successful receipt, but then won't change the physical resistance.
I've got a couple interval workouts I've built, and it's a workout-killer if the thing doesn't adjust going into or coming out of a hard interval.
The best "fix" I've got is to send the change requests intermittently, not just when the workout changes, but that can cause issues too. The kickr is a bit of a diva.
Your solution of having a ramp is good too: Assuming TR sends the same "set erg mode level" packet once per workout-level change, then it forces it to send a pile of them going into and out of the hard interval, increasing the likelihood one of them will stick (90% of them usually do, but if the one that misses is the start or end of an interval, :sadface:)
STAC Zero Trainer - Zero noise, zero tire contact, zero moving parts. Suffer in Silence starting fall 2016
Re: Controlling the Kickr via external power meter now possible [AHare] [ In reply to ]
All of your post was very insightful for how this trainer works with the applications.
That comment had me laughing. It seems like a great description. :-)
I've been lurking here for a while now, it's an interesting thread on the 'inner workings' of the KICKR. There's a KICKR app in the App Store I wrote a while back as a bit of a side project. Would be nice if Wahoo setup a dev forum themselves...
I've seen the same "erg doesn't adjust" connecting via BTLE. My initial approach was to set the Erg power once at the start of each interval, excluding ramps where the power was set continuously (say 5-10 times per second). This worked well for the constant intervals, but resulted in the ramps being delayed (slope of set power not matching actual power), the KICKR was not keeping up with the erg power values I was sending it. Once a ramp finished, it would take some time (say 30sec) for the KICKR to catchup. Current solution is to simply send a set erg request at a lower frequency (1-2 times per second); this seems to work ok, although has the potential to introduce some small delay to the start of intervals.
I imagine TR similarly limits the number of set erg requests being sent to the KICKR, so adding a ramp before an interval may not fix the issue you are seeing. But based on my observations it's the KICKR doesn't lose requests, it simply struggles to keep up with them, so sending a "pile" may not help things.
Power match type capability is something I was thinking of adding a while back, but this thread has kind of convinced me it may be a can-of-worms and I'd assume Wahoo (via firmware) would be better able to support this.
FWIW, I found the Wahoo API (iOS and Android) really easy to work with. Appreciate this isn't available on desktop environments, and if dealing with ANT+ is anything like writing custom *.fit files, well you have my sympathies.
Re: Controlling the Kickr via external power meter now possible [lock_] [ In reply to ]
A "pile" for me would be 1-2 updates per second. I learned very quickly that ANT+ devices don't like it when you send requests (calibration requests, erg adjustments, sim-mode adjustments) before they've acknowledged the previous one. The kickr (not to pick on it, it's the only sim-mode device I've got) would frequently stick to a single sim-mode slope setting in my first implementation because I was just hammering it at 4-5hz without waiting for acknowledgement packets.
Writing custom ANT+ code is an big pain. It seems like it shouldn't have to be (it's little 8 byte packets getting sent and received), but their API is just kinda weird. That said, it is possible that ANT+'s SDK has improved since TdG was under heavy development. As a part-time dev, I never had the time to write a nice wrapper I was happy with.
I wonder if Wahoo's phone driver just sticks your calls in a FIFO queue and unloads it at whatever the update rate is. It'd be fun to queue up 1000 calls that set up a sine wave (peak every 100 calls) in erg mode or something and see how long it takes in the real world for the device's resistance to go from peak to peak.
I can barely grasp what you guys are talking about in the challenges, but I am appreciating the dialog that helps me understand those challenges. Though I have been quite turned off by the "silence is golden" and the "we will only talk to you if you open up a work ticket from our website and even then we will barely talk to you" approach of Wahoo customer service, I will say the one thing they seemed to do right it create a trainer that can be tweaked by outside developers through writing code that has allowed users to improve the trainer from its natural state.
Although there are challenges for application developers at least there is an open environment to make those potential improvements.
This is a good feature for the Wahoo Kickr compared to some "smart" trainers that use exclusive software and have no flexibility, such as, the Elite Muin trainer. Seems like a good trainer, but I prefer a more open environment for guys like you to be creative in improving the training experience for us.
Horchata wrote:
I've had a similar experience. At the start of an interval the Kickr is usually to the high side of the interval wattage in ERG, then there is this sort of game where TR is trying to adjust the Kickr to try to get it in line with where the interval should ultimately land at wattage wise. Ultimately, for me it makes for a less smooth feeling interval than if I was running the Kickr on its own without my PM controlling it. Very frustrating. Maybe TR has improved its algorithm as I have admittedly used standard mode for the last few months out of frustration (and thus turned my Kickr into a dumb trainer).
At least a few months ago the braking sensation that I was getting when using external PM to control the Kickr in ERG mode was so bad that my cadences would always slow down until I was down in the 60s range. I was generally pretty tired going into the workouts so I didn't have the energy to spin, but it always felt like I was fighting to get the cadence back up. That's when I went to standard mode just to get my workouts done.
Thanks for your input.
We need to tweak our power match algorithm to take into account cadence. We've had a group of users who respond to more resistance by lowering their cadence. If you do that, we think you're farther behind the target and add more resistance after seven seconds, then the user lowers their cadence even more because they feel more resistance. This continues until you get pissed off and give up.
To get past this flaw in our algorithm keep your cadence consistent even if you feel more resistance.
The other choice is to use a constant offset. So if you know your Kickr reads 20 watts higher than your Quarq you can set it to have a 20 watt offset. That way you don't have the constant changes of power but you will be able to work in ERG mode.
CEO at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
We've seen the same thing where we get an acknowledgement from the Kickr but it doesn't really change. We need to start an ANT/BT (mental) support group :).
We've been at this for almost four years now and we've just recently rewritten our entire bluetooth/ANT layer with everything we've learned. That layer is going to be in our new desktop app and ported back into our iOS app this fall.
To be fair to Elite, they recently opened up their API to software companies.
CEO at TrainerRoad
Re: Controlling the Kickr via external power meter now possible [Nate Pearson] [ In reply to ]
Thanks for that feedback Nate. That's really insightful and helpful. That would be really cool and interesting if you could take cadence into account in power match. I probably do respond to more resistance by lowering my cadence. If the algorithm was updated to smooth this that would be really cool.
I did toy with the idea of using constant offset, but the problem is that my Kickr is not off from my PM by a consistent # of watts. It seems to increase depending on how many watts I am pushing (closer when I am 100 than when I am at 270).
I also wanted to clarify that I wasn't blaming TR's algorithm for my issue. You guys have gone above and beyond to patch a problem that isn't even yours. My frustration is squarely directed with the Kickr's power measurement.
Thanks man :).
I think what we're going to do is if someone cadence changes by X amount we're not going to apply a new offset. This will give the Kickr more time to adjust its own internal resistance and hopefully let everything settle a little more.
The end result will be that it will only change the resistance if you've been super smooth for a good 10 seconds; meaning power, cadence and target haven't changed drastically.
CEO at TrainerRoad
I think i mentioned this cadence and erg issue previously.
My "smooth" cadence is around 97-99 in erg mode.
If i try to go a higher like 100+ the kickr seems to have a little trouble keeping up with my lack of smoothness at that rpm.
This often results in a lower average power for the interval.
In fact i can trick the software by ramping up rpm and then reducing rpm at the lower erg torque and get an ease up.
Re: Controlling the Kickr via external power meter now possible [lennyk] [ In reply to ]
Have you told this to Wahoo? They might be able to update their firmware to better support this.
CEO at TrainerRoad
Huge glitch tonight. Doing ramps (Keeler Needle) and TR (or Wahoo or some other evil evil party) decided not to reduce wattage after the last 140% ramp. So rather than sitting there for a few seconds it sat there for 4 and 1/2 minutes. No amount of stopping and starting would convince it to give me a break.
It is quite common, in my experience, for it to miss a change for 20 seconds (either at the start or end of an interval) but 4 and 1/2 minutes?
My kids learnt some new words tonight...
Re: Controlling the Kickr via external power meter now possible [iSam] [ In reply to ]
A crafty marketing person might say, "It's not a glitch. We are pushing you to train harder." :-)
That must have been brutal. I know when this Kickr and application interval hold over has happened to me at or near 120% FTP every second feels like an hour of brutality as if the clock has stopped. Good job working through it.
i just purchased a kickr and i'm already frustrated. here is my setup.
stages PM
garmin cadence sensor
wahoo kickr
gs6 android
gtab android
garmin edge 800
laptop with bkool free (will upgrade to premium if i like it)
all i want to do right now is have this thing work.
problems:
1) i've updated the firmware. currently when riding erg mode i put the power to 300 and no resistance changes.
2) i run ultegra di2 10sp and the gearing is skipping oh so slightly.
3) neither my phone or my edge 800 is picking up the stages
4) where is the box that lets you have the external power control the kickr?
5) the wahoo fitness app sees my power and cadence, but both are "unknown" vs garmin and stages.
appreciate any help. just read through dcrainmaker and some of this thread, but there are 40+ pages so i kind of gave up.
john
Re: Controlling the Kickr via external power meter now possible [ahhchon] [ In reply to ]
I forget if the edge 800 is on the list of "doesn't play nice with stages" PMs, but a buddy of mine has a stages which seems to have serious range issues when talking to his Timex head unit, my garmin 310XT, my suunto USB movestick, or his garmin ANT+ USB stick. Just for a session, try putting your edge 800 on the floor, extremely close to the stages (under the bottom bracket is good) and see if it picks up there.
Edit: He just talked to stages, and apparently "some of the tabs in the case are broken".
Another test that might affect all ANT+ devices: try to minimize your use of other 2.4ghz devices: no nearby microwaves, wifi, bluetooth, etc. Most consumer radio/wireless devices use the 2.4ghz spectrum, and can interfere with each other.
I _think_ the box to check is in the wahoo app on your phone, but I'm not sure. I'd definitely focus on your non-wahoo connection problems before fine-tuning the control settings.
Does your stages work outdoors with your 800?
I have had a 500, 510, 910, and now a 920 that all connect to my Kickr. And I have used them with a borrowed Powertap and my Vector PM.
What are you using to control the Kickr right now?
I rode Morgan this morning, had to take a rest after 7th interval,
When i tried to restart it would apply full brake, paused then tried again, would allow pedals to spin up to around 200w then grind to full brake.
This is the second time happening to me, cant remember where the logs are stored.
Re: Controlling the Kickr via external power meter now possible [karlw2000] [ In reply to ]
stages dropped power 3 times this weekend for very short periods. i contacted them and they said a tab is broken which is causing the problem. they want to spend 5-7 days for turnaround time. problem is i'm in the final 6 weeks of training for immd. no time for this shizam. really starting to regret this stages purchase. sigh.
i don't even see that button option, perhaps it's because my stages is not working.
john
Hahaha.
This happened to me this morning on Ansel Adams. i.e when it got towards the end of the second set of intervals I was knackered and my cadence dropped and the Kickr responded by getting even harder.
I appreciate the trick is to maintain cadence but I struggle when Ansel Adams is demanding 8 x 50 seconds x 135% of FTP!
Any timeline for a fix?
Thanks for this Kenny. This could be a Kickr problem. If this happens, let the Kickr come to a full stop and let it sit for about 20 seconds. After that, you should be able to spin up.
CEO at TrainerRoad
Are you using ANT or BT? This could be where the Kickr responds that there has been an ERG change even though there hasn't been one.
FYI, in our new app we're going to send changes to the Kickr every 3 seconds or so even if it tells us it's changed it's ERG target. That way things like this shouldn't happen anymore.
CEO at TrainerRoad
Is there a preference for ANT+ or BT with the Kickr and TrainerRoad?
Re: Controlling the Kickr via external power meter now possible [PSJoyce] [ In reply to ]
Bluetooth 4.0 (aka Bluetooth Smart). Less bugs, more reliable connection, less interference.
CEO at TrainerRoad
