Excellent question
The performances (rolling resistance, puncture resistance, measures, ...) of bile tyre ares carefully studied by some guys, showing the results on the web.
Continental :
The Conti GP4000S2 bring a very good blend of rolling efficiency, resistance to puncture, to wear, and dry/wet grip. Plus aero perf.
If we look at Continental tyres compared, the GP TT vs GP4000S2, according to my favorite tester :
GPTT is 19% better in rolling resistance
GPTT is 28% worse in resistance to puncture.
Not to mention significant difference in wear, and in aero, TT in front considered less aero that GP4000 (shape and tread design)
So, if you want to go safer, you go GP4000s2. If rolling perf only factor (ready to take more puncture risk, and forget the slight aero difference), you go TT.
My choice :
according to my favorite tester, Michelin Power Comp is near GPTT in rolling resistance, with same resistance to puncture as the GP4000 on the middle, but the sides more fragile. On flat Tri, not too much on the side. Eric Lagerstrom choice, apparently, for non draft Olympic and 70.3.
If mountain and lot of curves, holes and little rocks, will go GP4000s2.
Pros :
Many "Continental" pros go GP4000, many others go TT, some other have specials (seen a picture of GP TT Hawaii, with same tread design as the GP4000), also to cope with higher temperatures ?
Do you know the % of "chance" to get a puncture on the Hawaii 180 km ?
