ericMPro wrote:
TheStroBro wrote:
ericMPro wrote:
TheStroBro wrote:
ericMPro wrote:
Titanflexr wrote:
However, the main advantage is comfort (and thus ability to stay in aero) because the weight is distributed along more of the forearm. There is also more surface contact/friction, reducing the forward saddle slide for many riders.
I'd be interested in testing this claim... I couldn't possibly imagine it being any easier to stay aero.
Also, if weight is distributed wouldn't friction net out the same?
E
Having greater surface area to stay on from large pads has helped me stay in aero for a longer duration of time than the previous stock pads/pad holders I had.
So what, your elbows and hands would fail?
E
Fail? No. But make no mistake the speedbar with additional support for the forearm expands the load bearing surface area beyond just your elbows and this creates additional comfort in the position.
Right I get that but I don't understand how it "helps you stay aero" *longer*, like, what was so bad before that you couldn't stay aero? The only thing I can't stay on my TT bike is sitting up on the hoods.
E
I learned the hard way that small pads is NOT the same as bigger pads for aerobars.
I bought a new Premier Tactical, which is a great bike, but not a perfect one. It comes with the smallest aerobar arm pads/holders that I have ever seen. Small rectangles, probably 2/3rds the size of a 'normal' ergo cup. Still plenty solid for support.
Turns out that in my left forearm, that small area of contact leads to a cutoff in my arm circulation if I hold aero for more than 15 minutes. I've spent 5 months trying to adapt to it, thinking it would get better, but it hasn't.
I recently removed them and installed 'regular' Profile design round cups/pads, and voila - arm circulation problems gone.
So there is something to be said about cups/pads that are too small, and it probably varies per person (or arm, in my case). But I could definitely believe that such long arm holders would more gently redistribute pressure on the forearms, leading to more comfort.
