Sram Force 1x crank. All I did was take it off. Change chainrings. Put back on in the EXACT same fashion, now barely turns. Chainline is in the correct spot. Used same washers. The washers and dust cover on nondrive side never even came off the spindle. It spun freely prior and now doesn't. It's torqued as required. It's PF30. I've pulled up all the manuals. It's installed per the instructions. I've changed cranks on bikes more than I can count. What am I missing here? It's a 2018 Diverge Expert. Did the bearings magically go bad in that 30 minute change over?
_________________________________
The curious task of economics is to demonstrate to men how little they really know about what they imagine they can design.
