Cervelo P3 and Enve 7.8 clinchers
Anyone have this setup? Trying to ensure the 7.8 c isn't too wide.
Re: Cervelo P3 and Enve 7.8 clinchers [Carl Spackler] [ In reply to ]
fwiw, I get about 35mm between chainstays on my 48 P3(700c) lots of clearance on jet9+
didn't pull it off the rack, just slide wheel back out rear of dropouts and used calipers
old or new P3?
Powered by All Out MultiSport - http://www.aomultisport.com/
Re: Cervelo P3 and Enve 7.8 clinchers [BryanD] [ In reply to ]
New P2 which is the same frame as p3 and I run Hed Jet 6+ no problem, those are wider than zipps.
New, '15 model
Reviving this thread as I just want to confirm the Enve 7.8s will fit on a New P2/P3 frameset (2015). Anyone confirm? Thx.
Re: Cervelo P3 and Enve 7.8 clinchers [sailnfast] [ In reply to ]
Anyone confirm these fit on NP2/3?
I have used 7.8's with Schwalbe 25's on my NP2 and it's VERY close on the downtube but there is clearance. Rear tire I had to adjust the rear dropout screws a bit but it did clear
Re: Cervelo P3 and Enve 7.8 clinchers [Tall_Coffee] [ In reply to ]
Thanks, appreciate the response.
With a new P2/P3 (mine is P3 2014), the only "pb" I had is with Conti GP4000S2 25mm on the front, it is working but with only 1mm margin (in height, no problem laterally).
A bit better with Michelin Power Comp 25mm, but I feel safer with 23mm in the front wheel.
Close but works with Conti GPTT 25mm too.
I was having some issues with punctures & odd marks on latex inner tubes, however that seems to have stopped since I replaced the rim tape.
In the photo you can see how close it is to the downtube. I never had it rub but man it was close
Re: Cervelo P3 and Enve 7.8 clinchers [SteveM] [ In reply to ]
Coming back from training today with the P3, I noticed a slight rub when checking the types.
The front Conti GP4000s2 25mm, quite recent, very slightly changed shape, and at one point is slightly rubbing on the frame.
Definitely moving to 23mm in front :-)
Nice ride! And that's with the Schwalbe 25s?
