I've had no-end of trouble trying to setup my PowerTap on my Cervelo P3. Has anyone experienced similar problems and found a solution??
I had the receiver on the chain-stay on the indoor trainer and it worked fine, but outdoors it doesn't pick-up the signal from the hub (replaced batteries in hub & computer but still no luck). So... I moved it onto the seat-stay as directed in the PowerTap manual, and again, works fine indoors but outdoors nothing or just the occasional signal which causes speed to jump to 5km/h then back to zero.
I've tried varying the position of the receiver (it's close enough to the hub) and ensured the receiver is within 5degrees of been directed above the hub. I can get it to pick-up the signal fairly well in one position (very awkward on the aero tubing), but if the receiver slips by 1mm the signal is gone! But, if I put the bike onto my indoor trainer the signal is picked-up just fine!?!? This is very very puzzling. On the indoor trainer the receiver seems happy in a few positions, but outdoors it's hard to get it to pick-up any signal never mind a constant reliable signal.
Any help or advice or insight into what's happened would be very appreciated as this is driving me nuts.
