Ceramic Speed oversized pulley
Just started looking at these as an option, and was shocked at how expensive they are. Are they worth the price? Is it a noticable upgrade? Thanks
Re: Ceramic Speed oversized pulley [dwgrenle] [ In reply to ]
"Worth the price" is VERY relative
But Yes; If you have look at everything else (helmet, skinsuit, tire, tire pressure, wheels, clean chain, transition time, position, etc.) and you think $500 for 1-2 min on an IM is good value.
Having owned a Ceramic Speed cage I wouldn't buy one for the price. The cage is actually made out of some kind of plastic not carbon and it shattered on me. I would source one of the other brands out there with a aluminium or carbon cage. Minimal gains so depends if you have the $$$...
Re: Ceramic Speed oversized pulley [benleg] [ In reply to ]
That's a pretty optimistic prediction, probably.
I wouldn't give it even a moment's consideration personally. Immediate no.
I have an oversized pulley system with really nice bearings that I bought for less than $100. I don't know that it really makes a big difference but no way would I buy a Ceramicspeed pulley as the gains at best are minimal from what I've gathered.
I bought a Premier Bike OSPS. This post reminds me that I need to install it. I believe they are an improvement over standard pulleys, but there is probably little to no additional incremental value of a Ceramic Speed over many of the other options.
Re: Ceramic Speed oversized pulley [exxxviii] [ In reply to ]
same here, Ceramic Speed coated bearing pulleys and Premier chain....need to install.
Buy SLF Motion instead https://slf-motion.myshopify.com/
Anyone know anything about the aerodynamic drag of the oversized pulley? Even if you save 1-2w from friction, having it -1-2w as an aero penalty really defeats the purpose of it.
Re: Ceramic Speed oversized pulley [Rest] [ In reply to ]
We have started selling the ceramic wheels that are direct fit on Shimano cages. They are super easy to install, no flexing of the long cages, no long cage hanging down in the wind and cost less.
We found that some athletes were having trouble installing the full cage.
I think the wheels are a good compromise between performance, aero drag and cost.
Dan Kennison
facebook: @triPremierBike
http://www.PremierBike.com
http://www.PositionOneSports.com
Re: Ceramic Speed oversized pulley [trail] [ In reply to ]
Very optimistic indeed. What you get in friction reduction you will lose back in aerodynamic drag from the larger pulley wheels and longer derailleur cage. The faster you travel, the more watts you will give up to aero drag since friction is linear but air resistance is quadratic. I'm very interested to find out where the cross over point is.
Re: Ceramic Speed oversized pulley [dkennison] [ In reply to ]
Hey Dan,
Would the wheels fit with Ultegra 6800?
Re: Ceramic Speed oversized pulley [Tweeks07] [ In reply to ]
They do not. The wheels fit DA-91xx, UL-R80xx and R70xx series.
Dan Kennison
No
Of course it's worth $500 to gain a fraction of a watt. I also think a stack of $100 bills creates a good spacer for my TT bars. On a serious note, I've thought about, but then I imagine the hypothetical conversation with my wife, and I think better of it.
Re: Ceramic Speed oversized pulley [Celerius] [ In reply to ]
They don't have the optimal shape or rigidity for headset spacers. You're supposed to use them as tire boots.
I've been told by pretty solid source that the ceramic bottom bracket is a far better use of your $$. A former world class rider, he says he can feel the difference. If I HAD the money, I'd put it there first and have less issues as well.
Re: Ceramic Speed oversized pulley [ggeiger] [ In reply to ]
ggeiger wrote:
I've been told by pretty solid source that the ceramic botox bracket is a far better use of your $$
Haha... this is probably an autocorrect result. But it adds so much to this thread.
haha! So true and I guess a very valid autocorrect!
Even that is very minimal gains and I get sick of the rate you have to change out a ceramic bottom bracket compared to a steel one. A bearing is designed to reduce friction even steel ones so yes a ceramic one may be marginally better but yes it's marginal gains v cost. I do laugh at people getting caught up on the aero properties of a oversized cage though but that is slowtwitch for you...
Re: Ceramic Speed oversized pulley [Shambolic] [ In reply to ]
I would do the BB first. I swapped out a steel BB for Sram Black Box, then my cycling instantly improved. For the first time, I had faster splits than guys I had no right beating, with no more training. It was a huge difference, so I'm not buying that gains are "marginal" with the BB, it's significant.
Re: Ceramic Speed oversized pulley [Rocky M] [ In reply to ]
Phil Wood "carbonyte" bearings are just as fast as ceramic and they are steel.
You be the judge...
https://www.bikeradar.com/features/friction-facts-measuring-bottom-bracket-drag/
If you like spending the money then you go for it. I went back to steel based on I found no difference, they last a lot longer and they are a lot cheaper...
