I currently own a set of second hand ENVE 4.5s with Ceramic Speed bearings that feel to be getting gritty. Ceramic Speed recommends doing frequent bearing maintenance and regreasing as stated by the guy in video. My question is regarding what grease do slowtwitchers prefer to use? CS offers 3 different greases for their ceramic bearings. All around, TT, and Long lasting. The guy in the video recommended using long lasting grease, their "slowest" grease, at the beginning of every season.. Doesn't seem that long lasting. The TT lasts for a minimum of 600 miles. This doesn't seem worth the maintenance unless there are some numbers to back up the grease difference. The blue all around hybrid grease seems to be a mix between the two. Currently my hubs show white grease under the caps and around the bearings, so the all around grease was not used in the past. What bearing grease do you use? Also, please share some tips for bearing maintenance as these wheels and bearings are too expensive for the trial and error process. I live in a dry area and do not ride these wheels in the rain.
Links to the grease options and video maintence below.
https://www.ceramicspeed.com/en/cycling/shop/grease-and-tools/[/url]
https://youtu.be/m5tQy0776yw[/url]
