Canyon shifter tightness
Alright, what am I missing here? My aerobar keeps moving around on me even though I am tightening it to recommended force. Where is the correct bolt to be tightening so my bad doesn’t keep turning on me? Aero bars are profile design.
Re: Canyon shifter tightness [Sharkbait22] [ In reply to ]
I think you have successfully cracked the base bar…unfortunately. Remove the profile clamps and have a look…if the paint/coating on the outside of the basebar(H40?) looks chipped or cracked it’s a good sign they are done for (you can peel back the chips and expose the carbon where it will be self evident).
I have had the same thing happen to me with the same slipping / dislodging aero bar and I was certain I was using the correct torque spec too - using an actual calibrated torque wrench. I’ve since replaced the base bar with a zipp vuka alloy type.
Re: Canyon shifter tightness [Yutaka Sonik] [ In reply to ]
It looks good to be. Obviously some scratches but it doesn’t look cracked.
Here’s what mine looked like
yikes. I will dig down again tomorrow and see but just real quick I didn't see anything I would think was wrong.
Are you saying your base bars are rotating in your stem? If so, try a little carbon paste and tighten to spec.
Re: Canyon shifter tightness [Mudge] [ In reply to ]
Not the base bar but the profile design t4 clip ons that go on the base bar. Although that solution will work I would assume
