thatzone wrote:
Asking for a friend of course.
But seriously is there much differences between the 2? Thank you!
not really much of a difference in terms of accuracy. Now calibration is a different story. The CT is more prone to inaccuracy if not calibrated correctly since its a wheel based trainer and you need to make sure its been calibrated after the tire has been warmed up. If you ensure the same tire pressure is used each time you ride its pretty accurate. I used to use a CT with Zwift and did not notice a change in power when switching to the kickr. The Kickr is better though for sprints and climbs as I dont get any wheel slippage.
Andy Mullen
Team Zoot
