Can I use a carbon rail saddle on a Cervelo p5?
I would like to install the S-Works Power saddle on a Cervelo P5-Six
From the Specialized web site
  • Ultra-light and strong, oversized FACT™ carbon rails.
  • NOTE: Oversized 7x9mm carbon rails are not compatible with seatposts equipped with side-load clamp mechanisms for 7mm round rails.
My understanding of the clamp mechanism on the P5 is that it is considered top-down (even though it wraps around the side). Will this work ok ?
thx for any help!
Re: Can I use a carbon rail saddle on a Cervelo p5? [burner] [ In reply to ]
"yes" to answer your actual question (you can use a carbon rail saddle on a p5).
"no" to the saddle you linked. you'll need an adapter clamp (ritchey makes the saddle clamp assembly and your Cervelo LBS can likely order you one of you may be able to get the "square" rail adapter yourself elsewhere).
Re: Can I use a carbon rail saddle on a Cervelo p5? [James Haycraft] [ In reply to ]
thanks James - appreciate the response. Will likely go with the TI model instead of carbon.
Bringing an old thread alive. Would this be compatible with a Cervelo P5 Six if I want to use an oversized carbon railed saddle? www.bike-discount.de/en/buy/ritchey-wcs-carbon-single-bolt-clamp-kit-7-x-9%2C6mm-37191
If this is not applicable, would really appreciate a link to a EU store with the correct product.
Re: Can I use a carbon rail saddle on a Cervelo p5? [PhatMilton] [ In reply to ]
Yes, that’s what I used on mine.
___________________________________
MS: Exercise Science
Your speed matters a lot, sometimes you need to be very fast, where sometimes you need to breakdown your speed.
Re: Can I use a carbon rail saddle on a Cervelo p5? [IKnowEverything] [ In reply to ]
Great, thanks for the verification!
