...so is it the front or rear?
The Flo 30 front is radially laced, so yes, you could very easily re-lace it yourself. If it is rear, you could do it, by taking care to follow the same pattern...but two big things:
- as mentioned above, a cracked rim means there may be damaged spokes nipples. You may not be able to recognize those, while an experienced wheel builder might. Most likely, they'll only find that when they start tightening the spokes or detensioning them near the end. So, that may/may not matter.
- wheel builders are often pretty picky about whatever their favorite spoke prep lube goes on the threads. "What?!? I never use anything besides linseed/wheelsmith/loctite/earwax. Thanks for the thought, but I'm tearing this apart and rebuilding it the only true and correct way"
Since you said you'll have the shop finish it anyway, I doubt you'd save much $ lacing it yourself. A good wheelbuilder could do everything in less than an hour. If I was in your shoes, I'd take your cracked wheel all apart, clean the spokes really well, especially at the threads. Soak the nipples in soapy water, maybe drag a pipe cleaner through them...dry everything really well. The spokes are likely noticeably different from drive side to NDS, but keep them labeled and separated. Bring the builder the hoop, baggie of nipples, clean spokes and hub (and maybe a 6pack).
It'll be done in a few days, cost something like $100, maybe more if they had to replace spokes/nipples. Heads up, those CX ray spokes cost a few bucks a piece. Nipples are less than a dollar.
