I was changing the front end to the tri bike recently and have to disconnect all the cables to the eTap BlipBox. When I put them back together, nothing shifts anymore. So I re-paired everything again and the system is still not right.
Here is the symptoms: The BlipBox will only work with the last paired derailleur, but not both at the same time. For example, after I pair the BlipBox with the RD, then the -/+ buttons will move the RD like it should. Then I pair the BlipBox with the FD, the FD button will work as it should, but the -/+ buttons will no longer move the RD. it’s like the BlipBox “lost” the pairing with the RD (because the light won’t flash when the -/+ buttons are pressed). And vice versa.
Anyone has run into something like this, and more importantly, any suggestions to fix it?
