My rear brake caliper grouping has a nasty habit of sliding out of a neutral position to an angled one where it chafes against my rear wheel rim causing me to go extra slow. Anyone ever have this issue before? How the heck does it keep happening and how did you fix it?
Re: Brake caliper issue [wduke59]
.. sounds like a return spring can't do it's job anymore ..
___/\___/\___/\___ the s u r f b o a r d of the K u r p f a l z is the r o a d b i k e .. oSo >>
Re: Brake caliper issue [sausskross]
It can also be that the cable housing is too long or too short, depending on which side rubs.
Or the center bolt isn’t tight enough or it doesn’t have the gnarled friction washers.
sausskross wrote:
.. sounds like a return spring can't do it's job anymore ..I had the same issue last spring and it was indeed the return spring. Every time I applied the rear brake, when I let go of the lever the non-drive-side would stay on the wheel. Took it into my LBS, who was able to diagnose and repair it in no time.
What kind of caliper?
Got a photo of the caliper mounted and the set up?
This. Related is that the cable can be very stiff.
"Remember: a bicycle is an elegant and efficient tool designed for seeking out and defeating people who aren't as good as you."
--BikeSnobNYC
ecce-homo wrote:
It can also be that the cable housing is too long or too short, depending on which side rubs.---------------
--BikeSnobNYC
