gd28 wrote:
It's looking more and more likely that this year's Boston Marathon weather will be pretty similar to last year with cold, rain, and a stiff headwind in the forecast. I'll be running my first Boston Marathon on Monday and curious to hear any lessons learned from those of you who had to deal with the weather last year. It looks like will be quite a bit of downtime the morning of the race before the start. I've heard you're pretty much stuck waiting around in a field...is there anywhere to find warmth/shelter for those couple of hours in "athlete's village"? Any other tips or mistakes you made that can be avoided by a newbie?
4.5.5
I wore, and I kid you not, seven (7) layers of clothing last year, and I'm a hardy, weathered Canadian who quite enjoys running in the rain and in cool temps!
The problem, if you can call it that, is the waiting around to start up by the school. There's not much in the way of shelter and it gets really muddy when the weather is foul. Knowing that on a windy day with heavy rains, the odds of staying warm and dry are slim if you are not suitable equipped, plan accordingly. It's important to stay dry until you are generating your own heat out on course, so buy some extra-large heavy duty (clear, for the security people) plastic bags you can wear over top of all your run gear. Do not forget about your feet!! They must stay dry until it's go-time, so bag them up too!
I personally wore a few wicking base layers, then three items I felt I could peel off and discard one by one if I was starting to get overheated, then an outer wind/rain proof shell on my torso. My lower half was just a pair of full-leg length run tights and compression socks over top. I also wore a wool toque and simple latex gloves preventing wind chill numbed fingers to retain dexterity for zippers and so forth. I wore plastic bags on my feet until I was shuffling towards the start line, plus the large clear garbage bag over top of my seven layers of clothing. My plan was to ditch the garbage bag just before the start, but changed my mind as my wave got called forward. It actually stayed on until right around Wellesley! I was pretty comfortable the entire run and didn't suffer afterwards as my body cooled down, unlike (I think it was) three years ago, maybe four, when a cold front swept through just as I was through Brookline wearing just a tech t shirt and shorts. I got soaked stem to stern in the downpour, then got a bit hypothermic surprisingly quickly after the finish line in the cold, wet wind.
See you all on Monday!
Dave
